09-11-2011, 02:52 PM
Another freebie picked up with the hacker portable radio.
this is a large and heavy beast, but I found it unusual as it has an auto reverse function, so went to collect it, and the nice lady said that it works, but needs a good service, buttons stick, and has a hum.
So home we went, and got it onto the table, and could not resist a try, out with the lamp limiter, plugged in and switched on, nothing, apart from the 60w bulb lit up at full brightness, so first job I presume is to check mains TX, then change the smoothing caps, (2x 32uf) and change that cap, and take it from there.
I was lucky that it came with the operation manual, which has the scematic in the back, about 15 reels of tape, two microphones, and a bag full of different leads with connectors, so onwards and upwards, but feel I will be back for more help, I have not had much luck with reel to reel recorders yet.
