14-03-2011, 08:40 PM
this should of been easy ,i hade onebut sold it 2 years ago and regreted it ever since.
a tatty one came up on ebay wich i won for £12.50. when it arived i started it up with a variac, only sighn of life wasvalve heaters glowing,
nexed i checked the ht at the filter block, 156 volts.
locking at the circuit the em84 should of had 160 volt at pin 6 this was zero the feed comes from the afc switch, it turns off the magic eye when afc is turned off. i shorted the swich out and now had a loverly green glow from the em84.
next step was to connect it to the hifi and an arieal ,oh dear afew very low level distorted stations .
there are only 2 electrolitics apart from the smothing block ,a 4mf 400 volt smothing in the anode of the cathode follower output stage.the volts at its povitive was only112 volts should of been 140 volts,its 10k anonde load had also risen to 16.4 k so that was changed as well. the only other bit changedwas a 1mf feed to top of volume control
back to the hifi,oh dear nothing at all.
back on the bench. with a bit of wire feeding the arieal and using a crystal earphone as a signal tracer found ther was audio at the multiplex output sometimes ,nothing at the output .the local distance swich caused the intermitent signal , another switch tep shorted out after spending about an hor cheching everything around the output stage i found that i had bent the tag on the volume control and it was touching the body. oh well another on down to failing eye sight, but at least it was now working .
back to the hifi , i dont belive it only hiss . more of my fault all the messing about i had pulled the other end of the arieal from its wall socket.
not as sensitive as it should be but sounds wonderfull . next is a paint job on the black . clean or change the two slide switches and try a new ecc 84.
rob t
rob t
