18-08-2011, 06:51 PM
Today I received a VHF90. The seller said it had been in regular use until recently when it had just stopped.
When I tried it its was dead with no continuity through the plug. The wires in that were OK as was the fuse - 5A.
I started checking valve heaters but then some instinct directed me towards the dial lights. One had blown and after changing that it not only worked but is fantastic; I can get Radio 2 on a four inch bit of wire.
Obviously it should work sans light so that's something to investigate. I'm not going to take it to bits until I've put a Philips set I'm working on back together but can see it's been partly re-capped at some point. I have also noticed a damned great hole in the board with the high power resistors on.
- Joe
- Joe
