:helpme::helpme:suprohone,hi guys ive just been gifted this suitcase gram, its mono,
made in checkislavakia, havent stripped it down yet, but it has a lid which can be opened at the hinges to allow speaker to be moved around, theres also a little pocket in the lid at side of speaker to store plug lead and sound line when closed , the case is almost oval with a carrying handle[ strap], the arm has two stylus, with a small switch to use either, [prob for different type records]'red and green dot.
trouble is theres a loud scratching sound when playing a record, there was also a lot of voice distortion, but i carefully cleaned the stylus with a toothbrush soaked in switch gear oil, as there was a lot of dirt around it,
at this stage not sure what valves are in place , but will open soon, would love to hear if anyone has knowledge of this little grammy, ill send a pic through picaso ,if someone will post it up for me , best regards maitiu
