03-05-2021, 08:23 AM
(This post was last modified: 03-05-2021, 08:26 AM by Radio Fixer.)
Replaced this due to slight leakage: machine is 10 years old but excellent condition as used only a couple of times a week.
Bought the new seal from eSpares that have a video of how to do it. All easy until the last bit of putting on a steel wire ring with a very very strong spring in it. This secures the outer part that is lipped over the front of the washer. After several attempts decided it was impossible as others had found. Perhaps Bosch have a special tool? As a temporary fix I 'daisy chained' tie wraps around it.
Later I found a video from Aus where the chap, who sounded South African, used a metal hook tool with a handle, through the spring eyelet, to pull it on for the last bit. Bought the tool but still couldnt do it
So finally, deciding that when the door is closed it compresses the seal to the front anyway I changed the spring to something lighter. Unfortunately the only one I had was much lighter but it works.
So far, several washes later there are no leaks
Gary
Gary
