15-10-2018, 05:17 PM
I've finallly taken a look at this lovely Davenset battery charger. ISTR I bought it at Harpenden years ago and it's been a static display item since then. The Vintage Wireless Museum has a similar or identical one in the vintage shop area. This used to be demonstrated regularly - the mercury vapour rectifier gave a lovely purple glow.
Mine has obviously been worked on. The transformer has been removed at some point. There are a lot of bits of choc block reconnecting the wires that were cut. The mains lead is some vile bit of rubber covered figure of 8 flex with a moulded 5A 2 pin plug. The cover of the transformer has been sprayed blue. It was alsmot certainly black crackle originally.
The transformer has multiple taps on the mains side. 3 at 20V apart at one end of the winding, 2 at 10V apart at the other. Probably 200V to 250V in 10V steps overall. The rating plate says 210V.
I've applied reduced mains via a variac with the bulbs and rect out. The transformer is working OK. The 2 tubular bulbs could be baretters, really not sure. One has an o/c filament, the other is mechanically poor. The rect looks a bit mechanically iffy but I have a NOS equivalent spare somewhere.
I've started to trace the circuit. So far just the primary and a bit of the secondary. If anyone has done this before it would save me the effort and I'd be very grateful.
Any info gratefully received.
After the building works and general revamp at home I hope to run this as a working exhibit. Possibly use it to charge the 12V SLA that I use to run my Rhumkorff coil. I know it's not ideal for SLAs but a bit of limited gentle charging won't do any harm
