11-09-2018, 12:26 PM
Pin 4 goes to HT. The odd thing is line op valve screen is fed via the frame op tx secondary and scan coils. This can actually improve picture geometry.
If you are eagle eyed some sets may be perfectly level on the bottom of the raster but slightly out at the top, a tiny amount of field flyback can clear this, it may be down to the scan coil design and cheaper to fix with just a rewire.
