21-12-2017, 03:24 PM
(This post was last modified: 21-12-2017, 03:33 PM by Geordie McBoyne.)
Many mid fifties TV sets were to put it bluntly made on the cheap. Yes, there was a lot of cheap and nasty TV receivers about in those times, however, the set I've chosen for this topic was although reasonably priced it certainly wasn't nasty.
The 1952 Sobell T143: This receiver always had only just sufficient picture height to fill the CRT mask, very little spare picture height to compensate valve and component aging.
In the Sobell T143 the frame blocking oscillator is supplied from the main HT supply. Later models such as the T144 and T145 employ a modified frame oscillator circuit. In the later sets the frame oscillator is supplied from the 320 volt boost HT supply. This modification has been carried out in my T143. As can be seen from the attachments there is now plenty spare picture height along with an improvement to frame linearity.
So to date the set has been fitted with Mullard AW43-20 electrostatic focus CRT and now it has an improved frame timebase.
Lets find out if any other modifications can be done to this set to improve it's performance.
Many major TV rental firms carried out modifications to TV receivers during the time the sets were in service.
Geordie McBoyne.
Geordie McBoyne.
