12-02-2017, 05:27 PM
(This post was last modified: 12-02-2017, 05:36 PM by pwdrive.
Edit Reason: addition
Make sure the IF transformers are tuned to the same frequency, but get the HT up to normal first.
On studying the circuit, it appears that the supressor grid of the EF39 (IF amp) is used as a diode anode to produce the AGC. I decided (probably incorrectly), that a malfunction of the AGC was increasing the gain to the state of instability. So - I shorted the AGC capacitor out, thereby disabling the AGC. The shrieking and howling stopped immediately. On 200 Volts HT, the tone was a bit rough, but on turning it down gradually, things began to improve. Finally, the optimum performace was obtained with an HT voltage of only 50 Volts. This gave more than adequate volume, excellent tone and selectivity. This suits me fine, because I can build an isolated PSU providing the required 50 Volts, that I consider a lot safer than the specified 220 Volts HT on a 73-year-old receiver!
Your third image along shows one exactly the same as I have in my diodes box!
