04-12-2015, 10:33 AM
Recently I was asked if I could repair the CD Player in a SONY Midi HiFi System in which bith the spindle and sled motors had developed high resistance. Not wishing to pay CHS £111 for a replacement mechanism, it occured to me that, since, AFAIK, the spindle & sled motors in all the common SONY & SANYO mechanisms are very similar, if I obtained a KSM213CCM mech. and swapped over the motors, a repair could be effected at far less cost ( I should know better!) so I purchased from CPC one of these, and proceeded to swap the motors. In the case of the spindle motor I also replaced the turnatable on the spindle motor with the correct one from the original motor, taking care to set the height at 18mm above the deck plate as in the original. However, when I refitted the mech. to the player and switched on, the sled motor worked OK, the disc loaded and clamped in place, but didn't rotate. A 'buzzing' kind of interference was heard in the speakers, so I switched off and rechecked things. Not finding any thing obviously wrong, I switched on again, measuring about 3.5v at the spindle motor +ve for a few seconds, but still no operation. The 'disc in' switch is working OK, and the spindle motor turns freely if rotated by hand. I should add that the mechanism had been left dismantled for 3 or 4 weeks, with the ribbon cable which connects the mech. PCB to the main circuit biard completely removed. Could this have caused a fault to occur on the mech. PCB? Both new motors measure ca. 11 ohms 'cold' resistance, which seems perfectly normal to me. NB I don't have the System or original CD mech. in front of me, and can't remember the model nos. of either!
