10-10-2014, 01:29 PM
A Leak Trough-Line tuner of similar vintage(ish) uses a 40uf + 40uf res/filter capacitor in a CRC configuration, if the Rogers has a reactance valve then HT ripple needs to be low. The HT filter arrangement in the Rogers is a CRC type, probably a CRCRC judging by the number of cut off capacitor wires, it looks to me as though the second filter resistor is just to the top left of the fuse holder as viewed from underneath.
Another observation is that one of the audio outputs is via a preset volume control, the other output isn't, the latter might be the output for a future stereo decoder.
