28-08-2014, 10:37 AM
I've been working on a dead PC and one of the faults was a dodgy electrolytic. I found it took considerable heat to remove the dud and then no amount of heat would suck the solder out of the holes. I struggled to fit the replacement but finally managed it. I assume the problem is the multiple layer on these types of board. Is there any special technique or tools that make replacing components like these easier?. This is my first attempt at fixing a motherboard. The newly fitted cap has done the trick and the machine is back in action. However, I'm not happy with the quality of the work and was wondering if there's an easier way to do it.
Cheers,
John
Cheers,
John
