03-08-2012, 02:56 PM
(03-08-2012, 01:08 PM)Robert Darwent Wrote: If you change the surge limiter to 10 ohms instead of the 33 ohms you are using at present you should find the voltage across the heater chain much closer to the 70v you are looking for, doing this also changes the capacitor value needed to 10.03 uF bringing it into tolerance.
Since a 10 ohm surge limiter produces a 3v drop instead of the 10v you originally allowed for, the resistor will only need a 0.9W power rating. So using a 3 or 5W type it should run much cooler and you will probably not need to make ventilation holes in the screening can.
Regards
Thanks Robert, I got carried away with the goal in sight
so the dropper is now in the can - but I have some 10 Ohm resistors so I'll make the change over the weekend. The only hassle is getting the nuts on to the bolts that hold the can in place - not a lot of room to work among all the coils!Soon I will have to tackle the glass dial issue - that's going to take some magic to find a workable solution. Thanks for posting the scan.
Cheers, John
