12-08-2011, 06:32 PM
i have a marantz cd player 400 series trouble is the display is now so dim its hard to read anyone any ideas?
thanks rob t
thanks rob t
marantz cd400
thanks rob t
13-08-2011, 07:19 AM
Might not be the display at fault Rob. I seem to remember some of the VCR 'dim display' faults, were caused by a capacitor in the display circuitry.
Roger.
13-08-2011, 09:56 AM
yes i am hoping that its only a cap but a search on the internet surgest its a common failure te problem being that the display is left powered when swiched off ie itonly goes into stand by there is no mains switch.
the one i have has been modified by njoe tjoeb to incorperate a valve output stage and sounds fantastic so i woul like to cure this annoying fault rob t
13-08-2011, 12:45 PM
(13-08-2011, 09:56 AM)tiv48 Wrote: yes i am hoping that its only a cap but a search on the internet surgest its a common failure the problem being that the display is left powered when swiched off ie itonly goes into stand by there is no mains switch. Quite often dim displays on VCRs and microwaves are due to electrolytics developing a high ESR. If you don't have any means of checking the ESR, it might be wise to change any electrolyics in the display module. (No good checking their capacitance with a capacitance meter, as they'll probably read fine). Best of luck with it - nothing ventured, nothing gained! David
13-08-2011, 03:10 PM
thanks yorkie i have an ers meater but cant find a circuit so not shure ware to look
rob t
13-08-2011, 03:59 PM
(13-08-2011, 03:10 PM)tiv48 Wrote: thanks yorkie i have an ers meater but cant find a circuit so not shure ware to look This might be of help Rob. http://www.eserviceinfo.com/index.php?what=search2 Roger. |
