22-10-2023, 06:33 AM
(21-10-2023, 10:35 PM)Jez Wrote: Some interesting historical perspective there....
If/as/when I get some rod pentodes to play with I think I'll be using my method. It's comparatively complicated but I reckon it should satisfy the needs I have for circuitry with cathode biasing, grounded grid, cascode amps and cathode followers etc.
What I'm thinking of is a master filament supply of something like + & - 12V (another separate isolated set of supplies floated up at say 40V or whatever for high cathode potential uses such as cathode follower or cascode as necessary) very well smoothed and regulated, which power current sources and sinks. The valve filament connects between them and has a pair of 1N4148 or a 1.25V bandgap reference between filament + & - to maintain 1.25V actual filament voltage (hence actual filament see's voltage drive) whilst a DC servo op amp adjusts one of the current sources to centre the cathode voltage to where it is required. Op amp and current source forming a sort of DC transconductance servo loop. This last bit would also allow bias to be accurately adjusted and maintained as desired to any reasonable point between around + & - 8V ish, hence simultaneously providing adjustable fixed bias whilst the cathode floats at many Meg Ohm away from ground and rails from DC to at least a few 100 KHz (filament chokes or common mode choke could be used to extend it to MHz etc if needed. Obviously the scheme is mainly intended for audio work). Et voila, instant "indirectly heated" valvesThere could be a gotcha I haven't thought of here of course!
Probably talking 6 transistors and an op amp per rod pentode to do this. Worth it? For potential high end hi fi use's then yes.
That's taking me a bit to follow. Although I do occasionally deviate into digital control I must admit my experience often tells me to go for "kiss" methodology.
Tracy
