31-12-2015, 01:17 PM
Looks like 4v/80v was standard, see items 40 to 41 in the link below:
http://jcverdier.museum.online.fr/nouvellepage9.htm
Recepteur Type RI 221
http://jcverdier.museum.online.fr/nouvellepage9.htm Lawrence.
01-01-2016, 12:52 PM
I've managed to identify the other two valves, Mullard PM1 HF (RF amp) & Mullard PM2 (1st AF) had already been identified, I initially knew that the Det valve was a Mullard but wasn't sure of the type, shining an LED light at various angles revealed that it was a Mullard PM1 LF, it's an early one, the Mullard logo is the antenna & inductor.
The AF output valve was more of a challenge, no ID marks whatsoever, however the anode shape is trapezium type, only one I could find that fits the anode bill with the same style of valve base (which is open at the bottom) is the Cossor Stentor two, 100% as I can be that this is the one: http://www.r-type.org/exhib/aat0008.htm I'm still with the "La Radio Industrie" theory on the ID of the receiver, they appear to have been a more specialist manufacture, there equipment was associated with the aero industry, they did some domestic receivers back then but not many so far as I can find out, later they were involved with early TV systems/components etc Lawrence.
01-01-2016, 05:17 PM
A bit more info, been on one of the French radio forums, the consensus at the moment is that the original valves would probably have been 3 to 4 volt types with a filament current of 60 ma, that would tie in with 8 ohm rheostat given it's physical size and allowing for de-rating etc.
A typical type being one of these or it's equivalent: http://frank.pocnet.net/sheets/084/r/R14_Rat.pdf The receiver as a lot in common with the C119 arrangement as shown in the schematic in this link: http://jacrieth.free.fr/TSF/Angic2.html Lawrence.
01-01-2016, 06:06 PM
See, I told you the Chauffage couldn't be 2V with a 4V Supply as it's too dangerous
![]() Alan
01-01-2016, 06:22 PM
Ah but Ah but, with the rheostat set to S/C the 2 volt valves that are fitted would be ok, but yes originally low current filament jobs, initially I was thinking bright emitters, TM type....must have been the sherry in the trifle...
Thanks for following this thread by the way...still a fair way to go for positive ID, if that's ever attainable, : "La Radio Industrie" of Paris is the front runner with me at the moment. Consensus on the year of manufacture seems to be around the 1924 to 1926 period. My own view as it stands is that it's not a bog standard domestic receiver model, maybe built for amature, communual, government, that sort of thing. Lawrence.
01-01-2016, 08:17 PM
I think it's fascinating, and I can't think that anything that complex was either 'Domestic' or even 'Amateur'.
I'd go for 'Diplomatic' as opposed to 'Military', but ..... You're going to have to fire it up otherwise we'll all die of curiosity. Do the Coils look Dry? Are the Switch Contacts in any sort of condition? Alan
01-01-2016, 08:55 PM
(01-01-2016, 08:17 PM)AlanBeckett Wrote: I think it's fascinating, and I can't think that anything that complex was either 'Domestic' or even 'Amateur'. Alan,the coils are wrapped in cloth tape, which looks like they might have been varnished at some point, all the RF coils read continuity on the ohms range with an Avo 8, I would say as it stands that the coils would go again, no sign of green spot on their external connections. All the switch contacts show continuity in there closed position, the brass turrets on the bandswitch(s) rotors have some corrosion on there tips (the contact bit) they all showed continuity to the coils selected but I did not specifically note any ohms readings between contacts, the turret contacts will go again as will the phosphor bronze strips that form the other half of each contact, there is no corrosion on the latter at all, The three position lever switch looks in good condition too. One of the audio interstage transformers is shot for sure, no continuity on either primary or secondary, it might be O/C within the windings or corrosion at the screw terminal connections, the other one gives continuity but I haven't made a specific note of the values in ohms yet. As said before I don't actually own the radio so don't want to rip too much out, it's in its cabinet at the moment, I will take it out again at some point and measure the RF coil resistances and the transformers resistances, I might buy a cheapo digital meter for that as the probes on the old Avo aren't too reliable for low ohms readings. I'll also try and do some better pics of the switches and the RF coils. Lawrence.
01-01-2016, 10:25 PM
(01-01-2016, 08:55 PM)pwdrive Wrote: One of the audio interstage transformers is shot for sure, no continuity on either primary or secondary, it might be O/C within the windings or corrosion at the screw terminal connections, the other one gives continuity but I haven't made a specific note of the values in ohms yet. That's no big deal, I've got several. (01-01-2016, 08:55 PM)pwdrive Wrote: As said before I don't actually own the radio so don't want to rip too much out, it's in its cabinet at the moment, I will take it out again at some point and measure the RF coil resistances and the transformers resistances, I might buy a cheapo digital meter for that as the probes on the old Avo aren't too reliable for low ohms readings. Yes, that's a problem. On the other hand the Owner might like to see it working, and it would certainly be more valuable refurbished. Alan
03-01-2016, 01:48 PM
I've posted the details of the receiver on three French vintage radio forums, no positive ID yet, it's a mystery...
06-01-2016, 01:23 PM
Took the receiver out of the cabinet today and shone an LED light at a low angle across the control panel, It's Type RK 221 not Type RI 221.
Lawrence. |
