14-04-2014, 01:07 PM
There's a picture of an Ever Ready E233 in the link below if that's any use:
http://mw0gkx.co.uk/batteries/batts/e233.htm
Advance UHF Millivoltmeter VM 79
http://mw0gkx.co.uk/batteries/batts/e233.htm Lawrence.
From what I have read the Mallory TR233R was a zinc mercury battery, it in itself containing three RM3R 1.4 volt cells, there's a readable page on the different types on Google books.
http://books.google.co.uk/books?id=QmVR7qiB5AUC&pg=SA55-PA10&dq=mallory+rm3r&hl=en&sa=X&ei=e-BLU_rbI6bH7Aa3woHIAQ&ved=0CDEQ6AEwAA#v=onepage&q=mallory%20rm3r&f=false Lawrence.
14-04-2014, 01:39 PM
When you said 4.2 volts it made me think of the flat ones with the 3 cells side by side.
I have got a radio that takes two of those and they are not stocked locally so I used two packs of three AA cells.
14-04-2014, 02:05 PM
(14-04-2014, 12:37 PM)AlanBeckett Wrote: Don't think so Colin, unless AAA means 3 Cells. As far as I can tell the Battery should be around 4 Volts. I think you are right Alan ..... unfortunately the old boy passed away in early 1983, so I can't ask him! Your ebay link seems a good substitute. Colin
14-04-2014, 02:10 PM
(14-04-2014, 01:01 PM)AlanBeckett Wrote: This is apparently a substitute for the Mercury Version. 2 or 8 holders available from this HK seller: http://www.ebay.co.uk/itm/Battery-Holder-Case-Box-3-AAA-LR03-For-Flashlight-Torch-New-/390784024846?pt=UK_BOI_Electrical_Components_Supplies_ET&var=&hash=item5afc8b010e Colin
14-04-2014, 03:43 PM
Splendid! Thanks everyone, I'll copy the Information just in case I have to go in for construction again.
Just one thing, the Listed Battery is TM233R NOT TR233R, which I'm assuming is simply a Rechargable version. Alan
15-04-2014, 10:59 AM
The Thick Plottens!
I've now had a chance to look at the Manual properly and, despite the fact that the Plate on the Unit says VM/79/1 and the Manual says Issue 1 (Handwritten) they're not the same. The Manual is all about a Battery Version whereas mine has a Mains PSU built in - see Picture above. So, that may well explain the difference in the Battery Number. There's also an extra FP Switch on mine marked 'Charger ON'. So, I'd better see if I can make any sense of the wiring around the PSU and Switches. Alan |
| 4 Guest(s) |
