21-06-2017, 04:39 AM
The remainder of the then-current Jasonkit range was also advertised in HFN 1958 September, but on a different page:
The Jasonkit tuner list comprised the two original FM models, plus the Argonaut AM/FM unit and the Mercury switched FM unit. The 10+10 watt stereo amplifier was probably the Jasonkit version of the Jason J2-10, I think sometimes named as the Jasonkit Jupiter. And likewise, the forthcoming simplified stereo amplifier was probably the Jasonkit version of the JSA2, and its matching tuner would have been the Jasonkit FMT2 or FMT3. The Jason/Jasonkit FMT3 would directly replace the original fringe area FM tuner.
The Jason J2-10 and JSA2 were also both advertised in HFN 1958 September:
This advertisement for Jason products appears to be from 1958 August, and includes the JTV:
And this I’d place as being from late 1959, which was when the Mk III amplifiers were released:
It referred to the Jason JTV2, but the picture shows the JTV! Perhaps there were not yet any JTV2 production samples to photograph when the copy was prepared. In the Jasonkit series, the JTV was mentioned, but said to be the same as the Jason JTV2! So that was on the cusp of the transition from the JTV to the JTV2. Note that by then the Jason FMS2, AM/FMS2 and AM/FM2 were no longer mentioned. The Jason Prefect local area switched FM tuner was still in the range, though. I suspect that the new JTV2, with fringe area performance, was seen as being a suitable replacement for the fringe area FMS2. The AM/FM models, with MF-only coverage on AM, might not have sold so well. The AM/FM2 was anyway a “luxury” model, with no fewer than 11 valves. (Strangely, the Beam Echo Avantic BM612, announced in HFN 1958 September, also had 11 valves and a very similar specification. I wonder of Beam Echo used the Jason circuit?)
Interesting would be what, if any announcement Jason made when the JTV2 replaced the JTV. My guess is that it would have focussed on fringe area capability and AFC. I think one would have to search HFN for say the last quarter of 1958 and first quarter of 1959 as likely places to find such.
In 1960, the Jason Monitor replaced the Prefect, and the essentially identical Jasonkit Mercury 2 replaced the Mercury. Both the Monitor and the Mercury 2 used the JTV2 circuit, sans power supply. Now, the remaining Jason/Jasonkit switched tuners were all of the FM/TV sound variety, with none being FM-only. Demand for switched FM-only tuners had probably peaked and was on the wane by then.
And later in 1960, the Jason FMT4 replaced the Jason FMT3. But there was no Jasonkit FMT4; rather the Jasonkit FMT3 stayed in place. So, now there were one Jason FM-only tuner, two Jason FM/TV sound tuners, three Jasonkit FM-only tuners, and two Jasonkit FM/TV sound tuners. All of those models lasted until the demise of Jason. Clearly, FM/TV sound tuners were an important part of the Jason product line. Once Jason departed, there was, in the UK at least, a gap until 1971 when Lowther re-entered and Motion Electronics entered the TV sound tuner market, the former with a UHF-only model and the latter with VHF and/or UHF options. Although the JTV2 lasted into the UHF TV era, by then Jason appeared to be inactive in development terms, so there was no derivative that included UHF or an UHF add-on device. Likewise, as far as I know, Jason never developed an FM multiplex decoder for the FMT4.
Comparing the JTV and JTV2 chassis, it may be seen that the JTV2 layout was reversed, with the front end on the left-hand side rather than the right. So, the apparently larger-than-necessary front end cutout in the JTV2 chassis was not the result of carryover of the JTV chassis. Perhaps it was originally planned to use a standard turret for the JTV2, but a late change was made to the much more compact Fireball type. And possibly this one done in part to facilitate the very compact chassis used for the Monitor and Mercury 2.
Cheers,
Steve
Cheers,
Steve
