I need some help and guidance please.
I've decided to rewire the 10 plug to the valve base following the CAD drawing that was produced by Chris Colebrook. I started from the selector switch tag - yellow wire (pin 5 of the plug). This was followed by the heater - selector switch pin 10, black wire (pin 4 of the plug) and then heater 2 - selector switch pin 9 & 8, brown wire (pin 6 of the plug). I then went to add the wire to the screen - selector switch 3 which should go to pin 7 of the plug......but it doesn't. It goes to pin 8 of the plug! Have I missed something; wired it incorrectly so far or was it originally wired wrong.
Please note that yellow wire goes to the pin at the 12o'clock position in the second picture; the black wire is the next wire clockwise and the brown wire is the first wire anti clockwise to the yellow wire.
Thanks
Rob
Thanks
Rob
