15-02-2024, 11:20 AM
(15-02-2024, 09:57 AM)ppppenguin Wrote: ** If you have the skills, you can rebuild it from the ground up, changing things as you go along should you wish. All the source code is freely available. I'm not going anywhere near there.I discovered that Joyce, the Amstrad PCW8256 / PCW8512 / PCW9512 emulator for CP/M or Locoscript is a ready to go .exe for Windows, but for Linux you had to build it from source. Not fun. However I was eventually able to read some 3.5" CP/M floppies from a modified PCW8256 and then write a program in Perl to convert the old 7 bit + 1 Wordstar files to ASCII. Older Wordstar used the eighth bit for soft carriage returns and other features.
Gentoo Linux fans are famous for build from scratch. I've done it years ago for Linux. For 99.9% of people there is no need. Even for Gentoo, because current Chromebooks now use it and can run regular Linux programs, unlike earlier ChromeOS. Also Android only uses a custom Linux Kernel.
