12-09-2019, 08:31 PM
Thin tip large blade screwdriver, clamp part of laminations in vice and lever out end E
PP Amplifier output impedance matching
12-09-2019, 11:31 PM
I did that to get the first lam out of a transformer but not without clamping a power resistor to it for half an hour to soften the lacquer.
13-09-2019, 05:55 AM
Thanks Mike, Refugee.
Maybe an induction heater would work? The school has one in the science lab, I'll ask teach. Amie.
13-09-2019, 06:16 AM
Edcor do decent cheapish SE OPT's as does Hammond. A good valve to use with a 12k OPT is the QQV03-10, two beam 5w pentodes in one bottle. For class A you can move the load line about a bit, it's best to try and get it through or above the knee, see - http://www.valvewizard.co.uk/pp.html .
Andy.
13-09-2019, 07:42 AM
(13-09-2019, 05:55 AM)Amie Wrote: Maybe an induction heater would work? You don't want to heat the windings. It comes apart easily after the first couple are out.
13-09-2019, 05:50 PM
Amie, you also have PMs from me.
13-09-2019, 08:13 PM
(13-09-2019, 07:42 AM)Mike Watterson Wrote:(13-09-2019, 05:55 AM)Amie Wrote: Maybe an induction heater would work? Teacher wouldn't allow it anyway..........I asked. (11-09-2019, 05:08 PM)Kalee20 Wrote:(09-09-2019, 04:14 PM)Amie Wrote: In a pushpull output, does the transformer need to present an Impedance on its entire primary to match the individual R.a. of the valves used, or does it need to match the R.a. in each half of the winding? I was stuck indoors yesterday, and did some experiments, based on what I've read in several books on the subject, or, what I understand of what I read, I should say. The quote from "Kalee20" is the concise answer to my original question, its a more difficult subject to completely understand than I can manage at the moment......the valve wizard articles posted by Diabolical Artificer are the easiest texts I found to understand. Amie |
| 4 Guest(s) |
