26-04-2012, 03:44 PM
Lawrence: harmonic generator, Racal RA-17: scanned copy of hand-drawn sketch is below.
[attachment=4782]
To fully appreciate what the HG does in the RA-17 and why it's needed, a brief description how it works is required. In essence, the L/C filter (after the HG valve itself) is a low-pass filter: passes all freqs. up to 32 MHz. The O/P from that filter is fed to a mixer. The other input to that mixer is the 1st. VFO (MHz tuning). The output of that mixer is a 37.5 MHz drive signal that is fed through a 37.5 MHz BPF to a second mixer. Since the 37.5 MHz BPF is +/- 150 kHz wide, only the appropriate harmonic from the HG LPF produces 37.5 MHz drive to that other mixer. (It's that 37.5 MHz BPF that 'calls the shots' here). The consequence of that is that the 1st. VFO must be tuned in 1 MHz steps. to produce that drive signal. (The reason as to why a 37.5 MHz drive signal is required in the first place is not discussed here: it's a separate issue: but please feel free to ask!).
All that is made clear by a few numerical examples:
1st. VFO tunes from 40.5 to 69.5 MHz. To produce a 37.5 MHz IF drive signal from the mixer and its 37.5 MHz (+/- 150 kHz) BPF combination, the appropriate harmonic from the HG will be as follows.
1st. VFO: 40.5 41.5 42.5 43.5 44.5 . . . . . 69.5 MHz
Harmonic: 3.0 4.0 5.0 6.0 7.0 . . . . . 32.0 MHz
37.5 MHz: 37.5 . . . . . . . . . . . . . 37.5 37.5 MHz
Al.
[attachment=4782]
Al.
