31-01-2019, 05:12 PM
Big Bang test today! Connected the set via the isolation transformer and the lamp limiter. Switched on and stood back. The result was an almost imperceptible buzz from the speaker and after connecting the G5RV via some croc clips the set burst into life! Works on all three bands. To say I was chuffed was an understatement.
Left the set running while I rigged up a connection to an external FM dipole (my shed is all metal) and I do need a decent long wire, but the set worked fine. It does produce a fair amount of heat, but nothing showed any signs of over temperature.
I suppose the more experienced members would now start checking voltages to see if anything else is amiss, but I’m not experienced enough at this stage to do this.
I’m just thrilled that I brought a dead set back to life.
Thanks to everyone who helped with their comments and suggestions.
Cabinet needs painting but that will have to wait for the warmer weather.
