23-05-2011, 09:22 AM
(22-05-2011, 07:00 PM)Bushbaby Wrote: Hi All,
Ok I'm stuck!
I'm wondering whether to:
a) put the original cap back in and retry (I do have a spare UL41 too) but I'm concerned why it had a 8uF cap connected to the 16uF side?(see photo)
b) use a triple cap that I have that 32/32/16 but no fourth connector (cap has -ive can indication)
c) use a 16/16 500v can (RS) but I only have a 15uF 250v electrolytic to put in parallel with one of the 16uF side - I'm concerned that 250v is too low.
Help please??
Regards
Rob
The original cap is unlikely to be faulty, but the only way of checking would be on a capascitor reformer to see what the leakage is when it's been reformed, or to replace it with a brand new one, (not 'new old stock'), as sold by the BVWS. The correct value is -as you no doubt know, 16 + 32 uF, but the tolerance of smoothing caps (or more correctly, the smoothing and reservoir caps) was very wide when the DCA90A was rolling off the assembly line.
As to the working voltage of the cap(s), in AC only sets, this can be quite a bit higher than the mains voltage, depending on the mains transformer characteristics, but in AC/DC sets such as the DAC90A, will tend to be at, or below, the mains voltage. I think that typically, in the DAC 90A it will be about 175 - 180V, but you can check it to satisfy yourself Rob, so I wouldn't worry too much about the fact that the one that you have is 250V.
As to the 8UF cap connected to the 16uF side of the original cap, I can only assume that at some point, someone has assumed that adding extra capacitance in parallel, bringing it up to 24 uF, it might reduce the hum. The 8UF doesn't belong there, and if it were me, I'd take it out. I don't like the idea of paralleling electrolytic caps anyway - especially of diffrent values as you can't be sure how they interrelate to each other. It's not like paralleling say 2 x 100 pf caps to get 200pf in a tuned stage in the front end of a set, not subjected to high voltages.
Just a little tip about replacing the waxy caps in DAC90As:
Like most people I guess, I'd become used to either unsoldering the leads of the old caps, or clipping them off and soldering the new ones to the same tags. Then I realised that all the tags are 'twinned' and staring us in the face are spare unused tags, flat against the tag strip. All we need to do is to snip off the old caps, carefully bend those spare tags upright, scrape them clean, and solder the new caps to those 'new' tags. The attached pics might make it clearer. I've shown one of the way I used to replace the caps until I cottoned on to the spare tags, and another pic of another chassis in which I bent up the tags. I've also added a pic of the 0.1uF X Class cap that should really be used for the mains suppressor cap rather than a polyester one, unless you remove the supressor cap completely as it seems to make not one jot of difference, and many sets don't have them. Finally, I've added a pic of a cream DAC90A that I bought for £7.00 at Hornsea radio rally last year, originally looking very scruffy, but otherwise sound. I'm not a great fan of DAC90As, but at £7.00 I couldn't pass it by.
Hope that helps a bit.
Best of luck with the restoration Rob.
David
