12-07-2017, 05:01 PM
(12-07-2017, 04:43 PM)Murphyv310 Wrote: In my post I didn't mention valves at all. What I did say was that a little bit of the developments should be mentioned and possibly a little bit of familiarsation would be helpful.
We may use Digital but this is very much an analogue existence.
It was Trevor who mentioned valves, I did mention that analogue is still taught (as is materials science, essential stuff), just that analogue is no longer as important as it once was.
Generally, the analogue part of a system is nowadays mostly concerned with signal conditioning pre ADC or post DAC - that includes digital amps and SDR. The heavy lifting these days is mostly digital.
sıʌǝɹq ɐʇıʌ `ɐƃuol sɹɐ
ʞɔıu
ʞɔıu
My point was actually to say that a grounding in analogue will not only complement digital but it can make the engineer see that it is quite possible to get the same end result in a simpler way that won't need a complex computer or back up that only the designer can repair or programme.
