04-10-2012, 02:59 PM
Well time to make a start.
It works to a fashion, but with a slight mains hum that does not vary with the volume, the record deck controls stick so needs the old grease removing and new reapplying, but the cartridge seems ok.
No lock on stereo on FM, it tries to break in as you tune towards a station, but only for a split second, not even long enough to light the stereo indicator, I may struggle with this problem, unless someone knows the fix.
The old rectifier is an AEG B30 C350/250, could someone please tell me if this is a suitable replacement if required as I have one in stock?
http://uk.rs-online.com/web/p/bridge-rec...s/2278508/
The schematic is included below.
All advice or suggestions will be gratefully received.
