24-10-2011, 10:18 PM
(24-10-2011, 04:22 PM)Retired Wrote: Hi,
Many thanks for the kind comments in post #1 David. I'll dig out the knob pictures and put them on the appropriate thread.
Its a lot different to wood turning isn't it?
Kind regards, Col.
Thanks for you kind words Colin.
Yes, on a woodturning lathe you have more freedom to make shapes such as coves and beads, and don't have to worry about the tool being on the centre line of the workpiece as the tool is in your hand and you place it where you want it, and most woodturning work doesn't need to be too accurate unless its thread chasing or making a lid to fit a box. But of course, with a metalworking lathe, as with woodwork, 0.1 mm reduces the diameter by 0.2mm!
I think the trick with metal lathes is to take fine cuts unless roughing out, and of course with acrylic rather than metal, a slow turning speed is more critical due to heat generated by the tool.
I think the big issue with woodturning is that of a 'dig-in' due to not presenting the tool to the wood at the right angle (with the bevel running), and of course, the risk when hollowing, or coming through the side or bottom of a hollow form. But if it does, so what - it's just a bit of wood so its really no big deal.
All good fun eh!
It stops my kids from putting me in a home:D
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
