27-11-2016, 03:32 PM
I just got the AVO MK1 valve tester out again, (1937 vintage, purchased on car boot sale), and found to my surprise, that it appears to be working normally now! When I first got it several weeks ago, it hardly worked at all. After cleaning the switch contacts, it was a lot better, but still way out, showing unused valves as poor/low. Now, it is showing unused valves as up in the 90s! I can only assume that it has been lying around for years in the freezing cold, and the last few weeks inside a warm house has rejuvenated it. I recall that at sea, we had a fixed lifeboat radio station in a small cabin in one of the lifeboats. This consisted of a set of 24 Volt batteries, and an MF/HF transmitter and receiver (valves). The small cabin had a low power heater in it that had to be plugged into a socket aboard the ship to keep the equipment warm. Sometimes, someone would pull the heater plug out, and when the radio equipment was checked, it would not work at all, having gone cold. After plugging the heater in again, it would start working after about half an hour. This was the case even in the tropics when it was normally boiling hot anyway. Maybe something to do with condensation more than heat!. Anyway, my ancient AVO Mk 1 is now OK, and will be kept warm and dry from now on. I find that most of my EF80s (ex TV sets), are round the 50% mark, but my larger EF39s, are all between about 60 and 90% with the odd one at 100%. Very pleased about this!
Bob
Bob
