21-08-2022, 09:49 AM
Hi Adam
There are many videos on YouTube that shows the method I used. This is one random example.
https://www.youtube.com/watch?v=G-PtnwtOR24
The power supply needs to be low voltage high current.
I was using my linear power supply but because of the low voltage it was running warm.
What I then used was one of those cheap china buck converters and a 12V 2A wall wart.
When making the electrolyte it was producing 4 amps at about 3 Volts.
You need to be able to control the current when electroplating too much or too little will give poor results.
I have heard that about 60mA per square inch is about right.
As the anodes are used up pieces break off and float around the electrolyte and can stick to the piece being plated.
After having filtered the electrolyte a couple of times to get rid of the crud.
I wrapped the anodes in some cloth. This has kept the electrolyte clean.
Frank
Frank
