30-09-2021, 11:54 AM
(This post was last modified: 30-09-2021, 11:55 AM by Mike Watterson.)
(30-09-2021, 02:05 AM)Panrock Wrote: All fascinating!There are very many display technologies now. Most will use a block of RAM for a frame, with the data three or more bytes per pixel, organised in sequential lines.
But what about the basic principles, e.g:
If one were to slow time right down and watch an old CRT display, one would see a scanning spot with trail, painting the picture in orderly fashion, pixel by pixel, line by line. Regardless of picture content.
But if one were to do the same with a modern digital display panel - or say a mobile phone - what would one see?
There are:
DLP (mechanical nano sized mirrors) Either one chip and a spinning colour wheel (R G B & Clear) or three chips. LED, laser or incandescent lamp
Plasma
CRT
LCD: Mono with backlight and coloured filter. There are three main filter layouts: vertical stripes, 2 x 2 Bayer like some cameras (R G and G B on alternatel lines) and R G B Y.
LCD projection: Mono with LED or incandescent backlight and coloured filter. Rarely three panels.
Mechanical Projection. Like a laser printer. No focus needed. Polygon disc mirror for lines, polygon drum for frame.
OLED: Not real LEDs, but diode like Electroluminescent dots with phosphors. Blue wears faster!
Real LEDs. Both giant walls and regular displays. Very expensive. Sony calls it Crystal LED. longest life.
eInk (milky liquid bistable cells with black and white particles). Usually mono (white, black and 14 greys) but a colour filter on top can give dim pastel colour or very dim colour (4096 variations only). Rubbish at video and ghosts unless entire page is refreshed.
Lower resolution may multiplex by rows (lines) then columns (pixels) for the entire panel. Two edges minimum. Or the panel may be in two parts separately refreshed, or four parts. A panel may have on board amorphous / thin film transistors at each pixel (LCD, OLED or real LED) and then there are less connections to the panel.
The display RAM can be two port or alternately accessed by the panel HW and the video output. Some panels thus need not be organised by TV line (row) and pixels per line (column).
DLP using a colour wheel in theory has to use four times the real frame rate. RCA before shadow mask had a mono CRT inside a drum with coloured panels.
The three panel (LCD or DLP) projectors use Dichroic prism block like in three tube or three chip cameras. The light source can be monochrome LEDs or incandescent or Xenon discharge on very bright projectors.
Single tube and then single chip cameras used vertical strip filters. Cameras now use
R G
G B
pattern https://en.wikipedia.org/wiki/Bayer_filter
The stripe system requires 3x horizontal resolution on display or sensor
The Bayer pattern needs 2x horizontal and vertical resolution, which is better for fabrication. It's also brighter on display and more sensitive on the camera.
The camera image, no matter if stripe, Bayer or three chip, is processed to give most resolution to the Luminance and less to hue/saturation, at some stage even if the data is RGB, which will be serialised as RGB per horizontal pixel, then rows of pixels then frames. Digital compression may need the columns and rows to be exactly divisible by 16, even though compress may use 8 x 8 blocks.
Common resolution schemes are 4:2:2 and 4:2:1.
Basically no matter how the camera sensor or display really does images, at some stage at origination and reception/display there is a frame of video organised by lines, pixels and what ever number of bits or bytes per pixel there is. Traditionally full colour used 8 bits each for R, G and B, thus 256 levels which is about 16.7 million possibilities. But there is now video with more levels and also images can have a transparency channel (though not usually for video).
A Screen Capture of a video frame (rare) or static image on many systems with a 16 shade mono eink panel will be in full 24 bit RGB colour. This is the case for ALL display systems and cameras; somewhere between the decompression and the panel one or more frames of video as horizontal lines of RGB pixels exist. There might be a separate RAM frame for the R G & B, or the bytes might be sequential in the "pixels" for the line.
