I don’t want to start a pointless debate about analogue v digital, and I’m not knocking Avos, which have a loyal following, and there are some applications where it’s useful to have a rising and falling needle rather than digits bobbing about in a meaningless fashion - when peaking a tuned circuit for example, using an RF probe. What I’m saying is that we need to be aware of the limitations of using analogue meters such as AVO 8s with an impedance of just 20,000 Ohms per Volt when working on modern solid state equipment.
I know that many forum members own Avos which they enjoy collecting and using to restore vintage radios, and since the original voltages will have been taken using an Avo 8 as a rule, which is 20,000 Ohms per Volt impedance - the norm for its day - the voltage readings in a working set should be similar to the datasheet. And I know that many like the idea of using vintage test gear to restore vintage radios. On valve radios, in which the voltages are quite high, the loading effect of putting a 20,000 Ohms per Volt meter across a resistor at a point at which say 100 Volts is expected would be negligible. It will have the effect of putting a 2 Megohm resistor across the circuit. (100 Volts x 20,000 Ohms).
However, on low voltage solid state gear, a multimeter with an impedance of only 20,000 Ohms per Volt can become problematical. If for example, we expect 0.5V at the base of a transistor, and we plonk an Avo 8 from the base to chassis, we are effectively putting a 10k resistor into the circuit (0.5 x 20,000 OPV). Apart from altering the voltage and giving a lower than expected reading, it may even stop the circuit from working - an oscillator for example.
To give a practical example of what happens, consider a potential divider consisting of two 100k resistors connected in series across a 12 Volt supply: We know from Ohms law that at the junction of the two resistors the true Voltage will be 6 Volts. Now consider what happens when we put a 20,000 OPV meter such as an Avo 8 across it on the 10 Volt range. Effectively, we are placing a 200,000 Ohm resistor in parallel with the 100k one in the potential divider, so the resistance drops to 66,666 Ohms, and as a result, the indicated voltage on an Avo 8 will be 4.8Volts. That will be an accurate measurement of the actual voltage of course, but not the expected or desired voltage due to the loading of the Avo disturbing the circuit. On an Avo 7, which is only 1,000 OPV, the result would be even worse – on the 10V range it would impose the equivalent of 10,000 Ohms across the resistor, so in parallel, the resistance would drop from 100,000 to just 909 Ohms, and hence, the voltage would drop to just 1 Volt. Conversely, a digital multimeter (or for that matter, a Valve voltmeter) with an input impedance typically of 20M OHM, would show the expected 6 Volts.
The formula for calculating the voltage in a potential divider is V2 = V1 x R2/R1+R2
So in the example of an Avo 8 above, the sums are: 12 V x 66,666/100,000+66,666 = 12 V x 0.399 = 4.799V due to the loading of the AVO 8. That is the actual voltage and the Avo is measuring it accurately, but it's 4.799V due to the loading effect of the AVO on the circuit. I’ve attached a sketch which perhaps makes this a little clearer.
There’s a useful parallel resistor calculator at this link:
http://www.sengpielaudio.com/calculator-paralresist.htm
Excellent digital multimeters can be had these days for pocket money. One such meter, which for me, was an impulse buy at just £10.00 at an auto-jumble last summer, is the Toolzone Full Size Large LCD Display Multimeter, which has an incredible spec at any price. I’ve attached a pic of mine. It incorporates a capacitance measurement ranges from 200pF to 20uF and an NPN/PNP. Unusually, it has a 200M resistance range – many such meters are limited to 20M. The large digits are very clear to read, and the auto shut-off is a handy feature to conserve battery power. Although it has AC/DC current ranges up to 20A, I’m not sure I’d want to leave the fairly flimsy test leads connected for very long at the top end of the current range.
Here’s the full spec.
• Auto Power Off (15 minutes)
• Big Liquid Crystal Display 3.5 x 6 cm
• Low Battery Indicator
• Continuity bleep
• Overlaod Protection
• High Impact Rubber Case with stand
• Probes and Leads
• Standard 9v Battery Supplied
Specifications:
• DCV: 200mV-20-200-1000V ........................+/- 0.5%
• ACV: 2v-20v-200 to 700V ..........................+/- 0.8%
• DCA:2m-20-200-20A..................................+/-0.8%
• ACA: 20m-200m-20A..................................+/-1.2%
• Ohms:200-2k-20k-200k-2M-20M-200M..........+/-0.8%
• CAP: 200Pf-20n-200n-20Mf.........................+/-0.2.5%
• Transistor Test: 1b 10MA Vce 3V
• Diode:3V/0.8Ma
• Dimensions: 200mm (8 inches) L, 95 mm (3 3/4 inches) W, 52mm (2 inches) H approx
There a many suppliers. Here’s one such supplier who has the meter at £16.00 with free delivery. (‘Toolzone Digital Multimeter Large’)
http://www.toolspot.co.uk/product/digita...eter-large
(No connection with this or any other commercial outfit).
Hope that’s of interest.
David
• Continuity bleep
• Probes and Leads
Specifications:
• Diode:3V/0.8Ma
David
