18-05-2016, 01:54 PM
(18-05-2016, 12:47 PM)Mark Hennessy Wrote: Goes to show that the chemicals don't work
How far in to the wood will they soak? That surely depends on the wood, plus how it's been treated? And how long do they remain effective once the fluids have evaporated? As far as I can tell, the health risks outweigh the potential benefits by quite some margin.
As an aside, it's quite surprising how humid houses can be - especially these modern hermetically-sealed ones!
Chemicals do work, it's what the whole tanalizing industry is based on.
The fluid will penetrate as far into the wood as far as the species, moisture content and the cut of the wood dictate.
As a rule, sapwood content will absorb fluid and hence have the highest chemical retention, heartwood wont unless it's been incised (or rotten) and even then with most species the fluid penetration due to incision will remain close to the incisions, Scot's Pine is the best softwood for heartwood incision, that's why the utility companies prefer it for their utility poles.
Most old radio cabinets will be made from plywood, face veneer aside, the plywood veneers used in the construction will generally be low grade sheets, most commonly softwood and most commonly wood from the sap band, that's the part of the tree that in timber production terms is of the least value unless the stand has been high pruned somewhere around the stands mid rotation, if it has then all subsequent growth will be knot free up to the pruning height apart from any possible epicormic shoots that develop after the pruning operation, ever seen a long length of new softwood joinery timber that's knot free? Well that's how it came to be.
The little beasties love the sapwood and the animal glue that's used, they're like most living things, they go for the easy stuff, munch munch.
The fluid is just the carrier, once it's done its job it matters not that it evaporates.
Houses don't seal themselves, all modern houses that are legally built and signed off have to comply with the building regulations, the regulations require means of ventilation, it's the occupants that seal them up, more fools them.
... somebody may not have read it before.
