22-06-2015, 10:01 AM
My son has a chum who has a Hacker Sovereign (doesn't know which version). It walked fine on all bands, but has stopped working on FM.
I don't really want to get involved in sorting it, but I wondered if there are any pointers as to typical faults, specifically on the Sovereign range that are likely to be possible causes of the loss of FM. EG, switchery, which a squirt of Servisol might set to rights, or loose FM antenna connection - or rather more involved - dodgy FM tuner transistors/diodes or whatever. I know in a way that it's a bit of a daft question, but without having the set in front of me, I can't be any more specific.
I note that the FM tuner of the RP18 has six transistors (AF121, AF125, 4 x AF114, and three diodes - BA112, 2 x OA79), so if just one goes down, that could silence the FM section. I also note that the FM section is a self-contained tuner unit ('Gorler' - not Mullard) and that the Service Data states: "It is recommended that servicing of the FM unit is confined to voltage tests and alignment, and should be returned to the Works should other servicing be required". Not a hopeful sign!
Any thoughts anyone please?
