23-04-2012, 09:36 AM
ah direct coupled transistor amps dont you just love them (all together NO!) a fault anyware in the circuit can cause mass destruction ,in this case even a fault around T1 (upsets mid point voltage) can kill t3,t4,t5.
the give away is inability to set quiescent current (4ma) on this one
ps yours uses the newer lfk4 package so line up is tr1 bc108 .tr2 ac128. tr3 ac127 .tr4 ac127 . tr5 ac128.
best of luck rob t
best of luck rob t
. Now go back and re-check every component - just like you did before. ( I know, I know!
) Until you can eventually escape that loop, there's no point in trying anything more adventurous - like trying to pass a signal through it. Next step is to set the quiescent current and check the temp. of the O/P transistors and check a few critical d.c. voltages.
