22-01-2012, 02:19 PM
Absolutely agree, not often we see on-line restorations on sets this age.
Andrew
Andrew
Pye MM
Andrew
22-01-2012, 03:58 PM
I think that I'd just rather tackle a faulty Tek. 475 'scope than that set!
![]() Al.
22-01-2012, 05:52 PM
I might take you up on that AL
![]() I'm hoping that it's just a matter of finding the duff bits and swapping them for good ones. I agree that a Superhet would be much more straightforward, but less of a challenge. Also, I suspect if it was Summer I'd want to get on with other things. As it is, provided I don't deperately need the bench for something else, I might as well plod on. As predicted I've been doing all sorts of domestic activities today. However, tomorrow's another day. Alan
22-01-2012, 07:35 PM
Hello Alan, looks like the finishing line is in sight, and it will soon be singing to you.
I have found the perfect radio for your next project ![]() http://www.ebay.co.uk/itm/Pye-25-portabl...lephony_SM&hash=item4161a27d92#ht_500wt_1361 Cheers Paul.
22-01-2012, 07:37 PM
What a mammoth undertaking the set project has proved to be - far and away the most viewed and responded to thread on the forum, with 173 posts and 2,745 viewings. It certainly goes to show that 1930s TRF sets aren't quite as simply and primitive as we might often imagine. A major facet of the restoration of the MM has in fact been mechanical rather than electrical, not forgetting Joe's efforts with the cabinet!
Well done on your considerable efforts Alan. Will it be going on display at Golborne in March?!!
22-01-2012, 07:58 PM
David,
As you say there are three parts to it, Cabinet, Mechanical and Electrical, so I suppose it's only 60 Posts each. I suspect that the major complication is Pye's efforts to make a TRF that just had a Volume knob as opposed to a separate Reaction Control. Without that, and with the usual two Tuning Capacitors, I guess it would be quite straightforward. Golborne in March would be a good target, I'll see what I can do. Mind you I'm just having a bit of a diversion with your ESR Meter - more later, elsewhere. Alan
22-01-2012, 09:10 PM
I've been distracting him too with questions about beer and the odd behaviour of my P224.
![]() - Joe
23-01-2012, 08:35 AM
(22-01-2012, 09:10 PM)ThePillenwerfer Wrote: I've been distracting him too with questions about beer and the odd behaviour of my P224. Alan's good at multi-tasking!
24-01-2012, 10:36 AM
Hi Joe, to think if they had used another type of glue, this would not have happened, i have used Rentokil in a spout can to kill the little blighters off, with great results, no more woodworm, i did my cabinet outside soaked inside and out, as it soon dries, also the little spout enables you to treat each hole if you wisk.......regards.....Alan.
| 8 Guest(s) |
