14-12-2024, 02:38 PM
I've almost completed the low voltage replacement circuit for the old Sussex Valve tester. I've noticed that the broken circuit has a TIP41a and I have some TIP41c's - just a double check if its ok to use?
I tried removing the old TIP41a but alas the emitter connection snapped off with no force against it in removal (doh!!) so I can't use it.
Thanks
Rob
Thanks
Rob
