02-11-2016, 12:19 PM
I have just repaired a Seaward PAT 2000I I was given a year or so ago. The problem was that most of the keypad was dead. That was caused by a faulty 4053 chip connected to the keypad matrix.
The problem I am left with is that if I power the tester up in less than 5 minutes after a power down it will often come up with the message "VOLTS ON NEUTRAL! PRESS # ONLY IF SAFE" Pressing the # key clears the message and then everything works fine. According to the manual this should only happen if there is greater than 50V between N and E. I am happy that this is not the case on any of the sockets I have tried it on.
Does anyone else use one of these testers? Does it exhibit the same characteristic or do I have another fault?
Al
Al
Tuned for maximum smoke .
