02-12-2013, 02:00 AM
This job applies to both valve and transistor radios.
This one was shorting over the bottom half of all bands and on close examination I could see that one set of vanes was out of line.
I set up the continuity peeper and adjusted the nut and screw and found I could not clear the shore without causing the other set of vanes to short so I set the nut to the middle of the range that cleared the short at the shaft end.
Then I further examined the vanes to see what end was worst and heated the solder on the mounting insulator and manipulated it to clear the short.
Success
Success
