18-11-2012, 06:36 PM
Rob I was thinking after you left today.
regarding the crumbly wire insulation on the VHF sets you are looking at.
Instead of replacing the caps and wiring in a blanket change, change the wiring first, then "that cap", then work through the caps and resistors.
You know it makes sense! Remember Cotterd and be methodical!
cheers Mark
cheers Mark
Keep on Fiddling!
