16-08-2019, 07:59 PM
I got a Sky Baron today.
It was initially "dead", but seemed to be dodgy pot/switch and also the LW switch. A few operations and it was OK. The crackles in tuning knob went with a good wiggle and the volume got a small dose of switch cleaner.
Seems very sensitive on MW, not so great on LW (no doubt because there is no LW coil, the MW coil is padded with 1250 pF). It had already been tweaked to 198KHz rather than 200KHz, though you'll still get R4 if it hadn't.
If it was even a battery valve set I'd be replacing the paper caps, but with only 9V (about 6V EOL) and low impedance transistors it's probably not an issue?
Bright was missing off centre of tuning knob. Cheapskates, no slow motion drive. I replaced it with one off a broken knob. Someone fitted a 1/4" stereo jack socket, but used the tip and ring. I suppose works for mono and out-of-phase both ears for a stereo headset, which oddly does sound better than in phase on headphones. Strictly you need a Stereo to Binaural processor to listen to stereo properly on headphones.
The R&TVS instructions are wrong re: C9 LW LO trimmer. Easiest way is to remove tuning knob and tuning scale and there is an access hole. It's not adjustable from the rear, though the IFTs are. Removal is via 3 x brass nuts, not the screws on the PCB. It must have had a TERRIFIC bash or been assembled bad as the Ferrite slab was resting on a wood barrier and stressing PCB. Tracks wrinkled but not actually cracked. I took out the two PCB screws and fixed that and then added solder on the tracks just in case.
I should check no-signal is 10.5mA. Leaky electrolyic caps are possible. As are dried out ones. Anyone any experience of this model?
Electrolytics C21 (+9V), C22 (driver emitter decouple), C11 (AGC decouple @ IF1, 8uF!), C20 (volume coupling to driver base).
Probably six paper caps. C4, C6, C14, C18, C19, C24, maybe C23?. Perhaps only leakage in C4 might be an issue, but it would need to be really bad, 39K from secondary HT and 10K in parallel. So likely any dodgy electrolytic is more an issue.
Someone swapped the original two pin PP10 plug for a pair of PP9 snaps. I've made a PP10 box and think I can fit 6 x Alkaline D cells in it. Looks about x3 capacity of a PP9.
Anyone got a spare PP10 plug or the dimensions?
