17-12-2018, 01:21 PM
Hi newbie here.
I am restoring a Cossor 480/470/835 vintage valve set. From no output I have managed to get a very weak output. By changing V4 an OM4 valve and several defective components.
Trying to align the tuned circuits with a signal generator that goes from 0Hz to 12 Mhz.
Successfully aligned the IF stages, then came the RF and Oscillator stages which requires an 18Mhz signal input.
Here,s where I have a problem as the sig geny only goes to 12MHz and it is quite expensive to buy one capable of 18Mhz.
Does anyone know of an alternative method of aligning these stages without an 18Mhz signal.
Any thoughts greatly appreciated.
Thanks
Llewellyn
Thanks
Llewellyn
