26-06-2014, 06:46 PM
The cable in question is a screened one just under 1 metre in length, which contains three individual cores, red, black, & blue, plus an inner single core screened cable for the audio siganl, the whole being terminated in a 6 pin plug to connect the head unit to the amplifier/ power supply. The outer screening is a heavy duty woven type, the problem being that the insulation on most of the inner wires has perished (as is only to be expected, I guess, since the radio is almost 60 years old!) Preumably no similar cable is manufactured today, so does anyone have any idea(s) as to with what to replace it? All I can think of is to use a single screened lead for the AF, and individual wires for the other connections, one of which carries the LT (6 or 12v) supply from the on/off switch to the amplifier, so needs to be rated at several amps., but if there is no outer screen, interference may well result. I've tried, without success, to pull out the old wires from the original cable.
