I bought this power supply some years ago from a car boot sale for £3.00 with no great expectation that it would work. The logo on the front 'Regulated Power Supply B' seems to suggest the outline of a power transistor - 2N0555 or whatever, so I mistakenly assumed that it would be solid state. However, when I removed the supply from its case, I discovered that it has three valves - an EL34, an EF86, and what appears to be a 150V regulator valve marked 'GD150'. The unit is solidly built to a good standard and has two transformers - one to provide 6.3V AC - the other to provide 150V fixed and regulated, (at only 7mA) and from 0 - 300V variable at up t0 60mA.
It has four fairly small metal rectifiers and on the rear of the main transformer there is a thermal trip set to trip at 400mA - far above the 60 mA that the unit is intended to provide.
None of the components (EG, electrolytics) have dates on them, and the serial number doesn't give a clue, but I guess it will have been made in the mid 60s. The manufacturer was Dukes & Briggs Engineering of Urmston, Manchester. Internet searches have drawn a blank - it would have been nice to have a circuit. One of life's little mysteries, and will remain so I guess. Quite how it found its way from Manchester to a car boot sale at Beverley Racecourse is another little mystery.
Luckily, to date, it's worked fine and often come in handy for such little tasks as powering the magic eye tester I've just made, so my £3.00 punt has paid off handsomely!
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
