28-04-2012, 04:09 PM
Hi,
This morning it was fine so I pulled the car out of the garage and got cracking on a nice little project. Our front door has two glass panels and I wanted to exchange the bottom one for plywood.
Yesterday in the rain I ventured out and bought a piece of WBP ply at 1/4" thick. First job this morning was to remove the glass panel then clean up the rebates and beading. The ply panel was offered up and marked with a pencil then trimmed to size on the bandsaw.
With all the sharp edges removed I then added an extra finishing touch by adding grooves. These grooves give the appearance of a panel made up of a number of boards joined together and the process is very easy.
I’ve never seen this done before but tried it as an experiment many years ago on a large garage door I was making. The width of the panel was measured then using a calculator I juggled the width of the “boards” to what looked most pleasing this being 3.5” each. The panel was carefully marked and pencil lines drawn in. A wide board was placed under the panel and a narrower wooden guide placed on top then both were clamped tightly with the guide up to the line sandwiching the panel. Using the tip of my tenon saw I ran the saw along the guide and cut to the depth of the outer veneer; the note of the saw changes as it breaks through and a black line appears which is the glue bond. Care is needed whilst cutting to ensure the saw follows the guide. With all the grooves cut I then spent a while using folded abrasive paper to soften the groove edges.
Cutting the grooves by hand.
When undercoated and glossed the panels look very attractive and much better than a sheet of plain ply. I’ve used this technique adding stained and varnished paneling to our kitchen and the result is most pleasing.
Home made panelling.
A router with a “V” cutter fitted could be used but I’ve never tried it as I feel the depth of cut could vary considerably especially if the panel is slightly twisted. I like using hand tools and this is one tip that doesn’t require power tools and costs nothing.
The picture shows the grooves being added and another picture shows our back door that I made when we moved here 25 years ago; the panel I’ve just done will look similar once finished.
Back door.
The reason for removing the glass panel is that we suffer the rare burst of sunshine which bleaches the hall carpet and we are having a new hall carpet fitted next week; another reason is our neighbours security lights directly across the street from us; they are like the Blackpool illuminations during the night.
I’ve just fitted the panel but am now rained off; I truly despair with our rotten climate and could cheerfully brick the telly every time I hear of global warming or a drought; this is why I sitting here on the computer when I should be painting the panel. The pictures are poor due to the black hole and it raining.
On a happier note though I’ve got a lovely project I’m looking forward to starting on shortly. The project is a new computer desk and already a rough design is in my head and yesterday I bought some materials. Oh for some warm; wind free dry weather. I hope this is of interest.
Kind regards, Col.
Back door.
Kind regards, Col.
