19-03-2011, 11:39 PM
(This post was last modified: 23-11-2011, 06:46 PM by AlanBeckett.)
The above question gets asked from time to time. I would guess that the vast majority of Vintage Radio fixers, for want of a better description, don't have one, and don't feel the need. I would suggest that they are wrong. After the usual small tools, bench, vice and a drill I would say that it's the next piece of equipment that should be aquired. Bear in mind that I'm not talking about Electronic Test and Measurement Equipment here, I thinking Mechanical. Also, bear in mind that I spent all of my working life with Electronic Engineering, not Mechanical Engineering.
The reason that I think it's a good idea is that opens up all sorts of opportunities to make things that are either unobtainable or expensive, such as knobs, shafts and extensions for example.
By the way, I'm not talking here about anything large, expensive and sophisticated, although that can make things easier. Just for fun a couple of years ago I mounted a tiny Super Adept Lathe on an ex-Sewing Machine Treadle table - see attached. It works fine, and I have an equally small drill which I intend to mount alongside it with a small vice to complete the kit.
Finally, if you want to know anything about Lathes, at least as far as Vintage is concerned, see Tony Griffiths site http://lathes.co.uk/
Alan
Alan
