28-12-2011, 03:35 PM
Rob - I'm intrigued by the Amplion 'Convette' battery eliminator, photos of which you have recently sent to the Gallery. I see one selenium rectifier, but the unit specifies two d.c. sources: HT and LT. So where's the other rectifier? And in the top left corner, I see what can only be a large wire-wound dropping resistor. What's that for? Do you have the cct. diag., please? If so, can you put it up here, please?
Thank you.
Al. / Dec. 28th. //
Thank you.
Al. / Dec. 28th. //
