31-07-2011, 08:11 PM
A bit off the subject of old technology...
I need to sleeve the first 25mm of a long M6 bolt, to act as a bearing. Outside diameter of the sleeve should be 9.5mm approx (could be 10mm at a pinch). So id is 6mm, od is 9.5-10mm.
Where do I get such sleeves?
I know at smaller sizes they are just a standard through-drilled stand-off pillar but I don't have anything suitable in "stock".
Any ideas?
It's light duty. For the wheels on a pair of ladder roof hooks (see below).
The old wheels disintegrated (plastic denatured by sunshine) and the new wheels from Ebay are perfect. BUT...the existing special shouldered bolts were so badly rusted they sheared when I tried to remove them.:badmood:
Any ideas?
thanks
Jeremy
![[Image: Roof-Hook_large.jpg&sa=X&ei=vrU1To_XIs-4...ae6cSZkn7Q]](http://www.google.co.uk/url?source=imglanding&ct=img&q=http://www.wickes.co.uk/content/ebiz/wickes/invt/530235/Roof-Hook_large.jpg&sa=X&ei=vrU1To_XIs-48gO2i8GhDg&ved=0CAQQ8wc&usg=AFQjCNFkAAPQ4GEl7kEtxVkTae6cSZkn7Q)
Any ideas?
Any ideas?
thanks
Jeremy
