22-02-2019, 01:31 PM
AVO battery completed. Piece of plastic trunking and two spacers made from dowel with a brass screw though. Coin cells held tight. Fits in well.
Lynton
Lynton
Roberts R66
Lynton
22-02-2019, 02:22 PM
(22-02-2019, 11:13 AM)Terry Wrote:(22-02-2019, 12:49 AM)Refugee Wrote: I made my AVO 15 volt batteries from five 3 volt CR2032 coin cells stacked with a 15mm water pipe stop end with a bit of tape wound around to hold it together. The myths start but if you use a second hand stop end. If the pipe had water in it then wet cells are needed and you need to open the battery compartment with a water screwdriver to fit it. If you use a new stop end you can only fit dry cells and the battery cover has to be fitted with drywall screws. If the stop end came from a gas pipe then life will be a gas and a safety police inspection will be needed.
22-02-2019, 03:05 PM
That's a conduit fitting, not a trunking fitting, but otherwise a neat bit of improvisation.
22-02-2019, 07:48 PM
(22-02-2019, 11:43 AM)pwdrive Wrote:(22-02-2019, 11:13 AM)Terry Wrote: You must start a new thread to discuss your mystical properties! Ah, yes, I think I can see what I overlooked. I must admit that I wrote my previous post in a bit of a hurry before I dashed off for a clinic appointment. In my rush I also left of the smiley I was intending to add, so I'll rectify that now ... ![]()
22-02-2019, 10:37 PM
The selenium rectifier which started all this discussion has some identification numbers. Maybe someone knows what this means?
STC D57 F8 1634A. The last digit 'A' may be a triangle? Difficult to distinguish. Any ideas? Lynton
That is a very impressive smiley
![]() Does that rectifier contain just HT diodes or LT diodes or some combination. It does not look obvious to me from the photos of the wiring. Once we have established what mythical properties apply to the stop end to be used in an AVO battery we need to work out what the polarity of the stop end must be and why? There is a right and wrong way to put the stack of cells together to make the battery and a reason for it. From this you get the polarity of the stop end itself. Another photo
22-02-2019, 10:55 PM
(22-02-2019, 03:05 PM)ppppenguin Wrote: That's a conduit fitting, not a trunking fitting, but otherwise a neat bit of improvisation. It Was a short piece of plastic tube I found in the bits and pieces draw which after a little internal boring on the centre lathe fitted the coin cells very well. The dowel came from an old cricket stump and the brass screws were M4 which threaded into the dowel quite nicely giving good tension on the coin cells. I could have spent more time sourcing plastic inserts but it does the job! Conduit, tube, trunkiing does it really matter? Lynton
23-02-2019, 12:00 PM
(22-02-2019, 10:38 PM)Refugee Wrote: Does that rectifier contain just HT diodes or LT diodes or some combination. It does not look obvious to me from the photos of the wiring. There is a picture in Post #20 that I missed earlier which makes things much clearer. The three connections on the right are the bi-phase LT rectifier and the two on the left are the mysterious LT protection diode . There is no connection between this and the HT - which hasn't even been mentioned in this thread, as far as I know! (22-02-2019, 10:38 PM)Refugee Wrote: Once we have established what mythical properties apply to the stop end to be used in an AVO battery ... Lawrence's reply made me realise that there was something I'd overlooked about the interior space available inside a compression fitting but I'm still puzzled. A stack of 5 CR2032 cells is 16mm high and I would have expected that this would exceed the space available inside the fitting which can accept something much greater than 15mm in diameter. I dare say that if I spent the rest of the day searching through the boxes and crates of what my wife calls my 'stuff' which have been in the garage since our move - a serious downsize - I should be able to find a compression fitting or two to inspect in detail but, to be honest, I can find more creative ways to spend my day! (22-02-2019, 10:55 PM)LyntonP Wrote: Conduit, tube, trunking does it really matter? No! Of course not! |
| 114 Guest(s) |
