20-10-2023, 07:50 AM
The few hours life was being over driven for power, proximity fuzes are related to radar, and that was only some types.
They can easily be longer life than RCA B7G 1.4V battery valves. In radio use the filament was run at 1.2V from NiCd and an oscillator may still run down to 0.7V or 0.8V unlike the 0.95V to 1V of 1R5/DK91 and later replacements. The only non-military two-way radio was a USSR model for forestry workers. Some models manufactured up to 1991.
There are some articles here and on the Radio Museum. Look for articles by Joe Sousa, an expert engineer in Linear Technology now part of ADI.
The 1j29b is essentially two valves in parallel sharing anodes (all rod tubes have a pair of anodes like flat rods. The g1 is a pair of flat rods very close to cathode filament. The g2 and g3 are focus rods either side of the beams. There are two beams. The 1j29b will do 1W. With one filament only it can replace most 1.4V audio Pentodes, but almost all the rod tubes work to over 100 MHz. The Russian sets used a 1j37b for AGC as the g1 connections are separate, thus a differential voltage (either polarity) steers the beams off the two anodes and reduces gain. They can also work as unusual mixers or frequency doublers or detectors.
I've used a pair of 1j29b to replace a broken KLL32, with suitable g2 pull down resistors. The two 1.2V filaments in series (common at one end anyway) work well enough off the 1.8V to 2.3V Lead acid cell I have. The g2 current sort of mirrors anode, so the g2 has to connect to an HT line or resistive divider. Strange instabilities will result using a resistor to set g2 current, because that doesn't work! It's part of an electrostatic lens so needs a voltage.
) and surely the heater IS the cathode hence all valves would "see each other" through the heaters/be cathode coupled to each other, at least partially, if not isolated from each other AC wise? I may well need to take NFB back to the cathode of the first stage for example.
cathode followers and GG could be "fun"!
