15-09-2017, 09:19 AM
(15-09-2017, 08:39 AM)Crackle Wrote:The transformer was huge Mike.(15-09-2017, 07:43 AM)Murphyv310 Wrote: It worked but was totally impractical and drew a couple of amps residual current, so as constant supply some what costly.Would that 2 amps be actual watts though, or would it be inductive, could it have been corrected with a PF correction capacitor?
I'd like to hear how you get on and what works best in your location, sometimes the oddest things help noise and trial and error often is the best way.
Good luck.
Was the transformer getting hot with no load?
Mike
It already had PF caps, it did say unloaded current 2amps on the plate. It did run fairly warm.
Don't forget smart meters charge for reactive loads, I was told this by OVO.
